I am attempting to fab a new gas line, fuel pump to carb. This is not a stock configuration as I have an aftermarket carb. So off-the-shelf is not possible. Two AN adapters will be used. Tubing is apparently measured as to outside diameter (OD). Many suppliers for adapters spoke of -6 AN to SAE 3/8". That seems to be a common size. But the stock lines for my 1967 327/300 seem to have an OD of 5/16". When flared (37*) they are 3/8" on the end. The AN parts are not available in 5/16".
I have two sets of AN tube nuts and collars in the 3/8" size. But the 5/16" tube is loose on the collar. That concerns me. It does snug up when tightened. So is the 5/16" a correct size for my engine? What engine uses 3/8"? I will post a pic.
