1962 Steering - NCRS Discussion Boards
1962 Steering
  • Bob Babcock
    1962 Steering
    I have about 90 degrees of play in the steering wheel of my 62 fuelie. Is that adjustable and how does one adjust it? .....or do I need to replace something?
    Thanks AGAIN, I seem to have more questions than answers.
    Bob Babcock
  • Mark L.
    • January 1, 1996
    • 121
    Re: 1962 Steering
    Bob,
    90 degrees is ALOT! If you adjust the worm gear to take it up you won't be able to turn lock to lock without binding.
    I hate to be the bearer of bad news, but it sounds like a steering box rebuild is in your future.
    • Dale Pearman
      Re: 1962 Steering
      WOW! must be a thrill to drive that one. Look in your ST-12 for complete instructions on adjustment. I suspect you might as well start taking out the entire column for an overhaul. Go to Corvette Steering Service in Anderson, S. C. . He's THE BEST on steering problems.
      Varooom.
      CLICK HERE
