What transmission fluids are best to run in a cast iron Powerglide? Mine is a '55 model.
Cast iron PG ATF
Tags: None
- Top
Re: Cast iron PG ATF
Dextron would be best, but, as Roy said, anything would work. The older style Ford type "F" fluid will make it shift a bit firmer, but that's not really a good thing on an older ci/pg. I'd stick with the Dextron III.Joel Adams
1974 Coupe
1985 Coupe
"I know the voices aren't real...but sometimes they have some really kewl ideas...."
- Top
