Distributor hold down clamp in 68. - NCRS Discussion Boards
  • Terry F.
    • September 30, 1992
    • 2061
    My May built 68 corvette 390hp distributor hold down clamp is the stamped steel version but I see several people describe 68 as using the wire style hold down clamp. Any opinion on this would be appreciated.
  • Dale C.
    Infrequent User
    • March 1, 1987
    • 26
    Re: Distributor hold down clamp in 68.
    Terry On 67's the stamped clamp would be on the 427 engines. The wire clamp is for the 327's. I believe the same is true for your 68. Dale
    • Terry F.
      • 2061
      Mooch-o thanks! Terry *NM*
        Terry and Dale-----
        I believe that all 1968's used the stamped steel distributor clamp, whether small block or big block. I would not rule out, though, that very early 68's might have used the earlier "wire" type clamp.
        Also, there were 3 versions of the stamped steel clamp used from 1968 to the present. These are pictured below. The one on the left side of the photo is the GM #3704912 used for 68-E79. Actually, this same clamp was also used for most C1 era small blocks, too.
        • Jim T.
          • March 1, 1993
          • 5351
          My original owner 68 327/350 has the heavy wire type hold down distributor clamp. My 70 original owner 350/300 has the steel clamp style on the left in Joe's posted picture.
          • Jim T.
            • March 1, 1993
            • 5351
            Reference previous post, 68 is a February built Corvette.
            • Terry F.
              • 2061
              I didn't think anyone had tampered with my clamp in the past. Thanks for the information. Terry
              • Jim B.
                • July 31, 2002
                • 146
                My very late 68 327/350 which I bought new and still have has the stamped holdown just like Joe has shown. I can't tell for sure if it has the markings that Joe is showing but it is the same configuration.
                Jim Boudreaux
                38390
                Jim Boudreaux
                LA Chapter, NCRS
                _____________________________
                1968 British Green Convertible 327/350HP Original Owner
                2002 Z06 Black on Black Original Owner
                2007 Z06 Velocity Yellow w/Black/Titainium Original Owner
                • Anthony S.
                  • April 3, 2008
                  • 183
                  I can't say for certain that my clamp is original, but I believe that mine is. I have a wire style clamp, My '68 is a 327/300 built 1-24-68.
                  My engine had most of the original parts (including the distributor) when I bought the car.
                    Jim------
                    Looks like the wire type clamp was used longer into 1968 than I would have expected.
