67 Trim Ring Part Number - NCRS Discussion Boards
  • Mark
    Can anyone tell me the correct part number for the '67 Rally Wheel Trim Ring? Thanks, Mark
    Re: 67 Trim Ring Part Number
    Mark-----
    No problem. Originally, the 1967 wheel trim ring was GM #3901708. Currently, the trim ring which SERVICES the 1967 Corvette application is GM #9796696. This part GM lists for about $60 each. I am not certain what, if any, differences that the original part and the current replacement part might exhibit.
    • Mark
      Thanks Joe! Does anyone know if there are any differences in configuration? Is this ring currently reproduced? Thanks, Mark.
      • Wayne W.
        • April 30, 1982
        • 3605
        The new part is a push on type and the old has clips. The outer ring is wider on the old and the valve stem hole is shaped different. There is also a difference in the overall depth of the ring, the old being deeper.
        • Mark
          Thanks Wayne, sounds like I don't want the repops! Mark
