Doing a little cleaning of my 64 FI unit. Have the fuel pressure line (1 of 2) disconnected. The long one that runs from nozzle cluster to spill valve of fuel meter.
Tried to blow through it but there is a restriction, used Carb cleaner and it does come out, however still hard to impossible to blow through. Is this normal, is there a restriction inside the tube (doubt that). Should I soak overnight??
Also tried my other tube (different unit) and found the same thing - so better to ask before I hurt it.
