Can someone post a picture of the correct installation of the vacuum advance line on a bb 71? It should be tight along the manifold the entire length correct? After about plug number 6, the rubber hose belongs on which side of the wire support? In the front the metal hose goes above or below the tube on the carb.? Thanks Kevin
C 3 Vacuum advance routing
