What difference between63&64 lower aframe - NCRS Discussion Boards
  • Stan E.
    • April 30, 1991
    • 383
    What is the difference between 63 and 64 lower a-frames and the same for the shafts Thanks stan19259
    Re: What difference between63&64 lower aframe
    Stan-----
    The EARLY 1963 lower a-arms had no reinforcing plate welded on the forward, inner vertical surface, just rearward of where the stabilizer bracket is attached. Later 1963 and all 64-82 had the reinforcing plate. So, when did the change occur? My GUESS would be ABOUT March, 1963.
    As far as the control shafts go, there were 2 style shafts used over the entire 63-82 period. One style shaft had a more-or-less "I" beam configuration. The other style was "flat", with no longitudinal "channel". Both of these style shared the same forging number. I believe that these styles were used interchangeably over the whole 63-82 period. However, one style or the other predominated during any given period. I don't know which style predominated during the 63-64 period. However, whichever style it was, I think that it was the same for both years.
    • Philip C.
      • December 1, 1984
      • 1117
      Hi guys I think you will find the change over later then March late May or June,63 the dog bones (shafts) 63-65 square 66 up round.Phil 8063
      • Harry Sadlock
        My April 20th 1963 does not have the extra support.
        Harry
        • Andy C.
          • May 31, 1987
          • 71
          Hello; My 63 air coupe does not have the reinforcement plates on the lower a arms! It was made in July 1963. andy
