If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I have found a couple of 'original' radiator caps for a 1973 Corvette, they have the AC logo and 13 lbs stamped on them in the recess at the brass rivet. The sealing rubber gasket is dried and has some small cracks in it. Is there anyway to replace this worn out rubber ring?
Roger
I know of no way to replace the rubber seal on the cap unless the center rivet is drilled out and replaced, too. I believe that there are some folks doing this. However, if you have a cap marked "13 lbs" then you have a cap that's not what you're looking for, anyway. The cap used for 1973 Corvettes was an RC-33 which was rated at 15 PSI. A photo is attached.
If you have a few donner caps you can heat the rubber up in water and remove the rubber seal and install it on your correct 73 cap. This will not work for older caps but should work for you.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
