C# WIPER DOOR WIRING - NCRS Discussion Boards
  • Jeff A.
    • December 1, 2001
    • 95
    Almost done with adding the wiper mechanism door etc. that someone took off the car previous to my purchase. The red wire with the white stripe is connected to the limit switch, but in the AIM and wiring diagram it shows the other end connecting to the wiper motor. The only possible place seems to be what looks like a ground connection ( single spade tab ). Is this the correct spot for the single lead coming off the limit switch pig tail. Thanks.
  • Geoff C.
    • May 31, 1979
    • 1613
    Yes it is. It's oh so easy when you know where *NM*
