Guys,
I'm thinking about doing suspension work on my 1963 SWC. From what I can see, the car needs front "A" arm bushings (what's in there now is dried out and cracked). the car sits low so I suspect the front springs should be replaced as well. As for the rear, basically the same thing; dried out and cracked bushings. The rear spring also could use a re-build. The rear end is original and should probably be rebuilt while I have it apart.
Question - How difficult (dangerous with springs) is this to do? I've done basically all the other mechanical work on the car myself and would like to tackle this as well.. Any thoughts or suggestions?
Thx,
Joel
Thx,
Joel
