Hi,
I still have an oil leak in the rear area of my oil pan. I originally posted in 10/2003 "can't stop oil pan leak!" and at that time replaced my rear main seal and put on another new FelPro one piece gasket (#OS30061T). I'm about to go in again and at least replace the gasket with another new FelPro one piece and was wondering if anyone had any further ideas. I know I should put sealant in the corners around the rear main cap but should I be using sealant anywhere else with this particular gasket? I also had to use slightly longer bolts on the pan at the rear main cap because I couldn't get the originals started because the gasket is so thick. With this said, should I be torquing the pan to the original spec's when using the one piece gasket?
Jack
Jack
