'70 Harrison A/C Foil Decal Location - NCRS Discussion Boards
  • Lawrence Berte
    It's time to stick on the new Harrison A/C evaporator case foil decal, but would like to know the correct placement on the case
  • Jim T.
    • March 1, 1993
    • 5351
    Re: '70 Harrison A/C Foil Decal Location
    Lawrence the case foil on my original owner 1970 is located on the front of the flat part of the case. It is positioned vertically with the side saying Harrison closest to the engine. About 1/4 inch of the bottom of the label is below the circumference circle of the the air conditioning valve mounted in front of the case/housing. The label is about 1/2 inch inboard from the front rounded edge of the case closest to the engine. The label is mounted on the flat front surface of the case. This may not make any sense to you, but I have known of this location for over 36 years. The left vertical edge of my decal reads EBA-70-69B in the top spot and SAE-AIR-60 on the bottom.
    • Gerard Q.
      • February 1, 2000
      • 284
      You know what they say about a picture
      Here's a pic of it's location on my 71
      • Lawrence Berte
        Re: You know what they say about a picture
        Thanks guys, that sums it up. Lawrence
