C2 64 Rim & Stem FYI - NCRS Discussion Boards
  • Alan Drake
    FYI - just removed my original tire from my original rim, spare!
    All numbers are in inches using a ruler so may be off a little.
    The valve stem is 1 1/8 high, with 3/4 of rubber and 3/8 of metal for cap. On the inside the round rubber is 5/16 high with two labels molded in which are 180 degrees from each other, "AG E" and "IR413"
    Wheel stampings;
    The two ridges at the valve stem area measure 1/4 X 1/8 and are 3/8 apart as measured from inside. Near the valve area the rim ismarked 15 X 51/2K with a "1" at a right angle to the 15 and a"64" at a right angle to the 1/2. about 1 away are two circles 1/2 dia, one saying Celsey Hayes while other has some kind of symbol.
    On the outside at a 100 degree angle is "GM" on the raised bumps towards the center of rim.
    The inside of the rim is entirely black.
    If your are looking for a 64 rim, hope this helps somebody.
    No questions today - just some data.
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: C2 64 Rim & Stem FYI
    Sounds like a true Ginny from Jan of 1964.
    Good for you..
    tc
