C2 wipermotor - NCRS Discussion Boards
C2 wipermotor
  • Twan B.
    • June 30, 2005
    • 207
    C2 wipermotor
    Today i tested my wipers after a had taken out my wiper trans. The wipermotor did make a tap (tick) The sound is comming from the pump for the washers.
    The only thing i've done is to put out the wiper trans inside the car and now it make this noise.
    I must say that the steeringcolumn is out off the car (incl. the cables for the horn and turn switch)
    My ignition switch is out off the car (bought an orig. one) and not connected.
    The wipermotor has had worked first-class before.
    Is it mybe a ground wire?
    Thanks!
    Twan #44079
  • Gene M.
    • April 1, 1985
    • 4232
    Re: C2 wipermotor
    The wipers will not operate without the ignition switch on or accessories.
      Gene's right...
      but your copy of the '63 Corvette service manual tells you how to bench test the wiper motor, repleat with what power/ground and jumper connections to make to exercise the unit when removed from the car...
      • Frank C.
        • January 1, 1986
        • 277
        Re: C2 wipermotor
        I'm fairly certain the wiper motor switch needs a good ground
        • Twan B.
          • June 30, 2005
          • 207
          Re: C2 wipermotor
          I connected the asc. with the Bat. on the ignition switch. Does it need the ground also??? (on the ignition)
          Thanks!
          Twan #44079
          • Gene M.
            • April 1, 1985
            • 4232
            Re: C2 wipermotor
            The ground wire originates at the starter motor mounting goes to the blower motor then to the wiper.
