Mine is held on by JB Weld as the connecting tabs are broken. I have experienced a couple of total ignition shut-downs in the last couple of years by that connector coming loose. Not fun! Lectric Limited obviously has a source because they sell $395.00 harnesses but won't sell individual connectors. Anyone know where I can get one?
1967 Ignition Switch Connector-Source?
Re: 1967 Ignition Switch Connector-Source?
Some of these connectors are LONG discontinued from Packard and now that Packard's been spun off (a division of Delphi), the bean counter's microscope is on them! Those who build reproduction wiring harness assy's sometimes have to special order in +10,000 unit lots from Packard to a given connector run specially for them and/or they have to redesign the connector's tooling out of their own pocket.
Don't be too hard on them for not selling an individual connector! Typically, the cost is less than a quarter and often fractions of a cent. They're in the business of building and selling wiring harness assemblies and onesey/twosey component sales are simply 'nuissance' transactions...
The way they look at it is, if you're missing this/that section of your harness, buy a replacement harness. OR, go to a scrap yard and gather the individual component(s) you need to repair your original harness.- Top
The original part number for the connector was 2989610. You might try the Standard parts catalog at your dealership. An alternative might also be to carefully remove one from a '65-67 Chevy Pass car.Bill Clupper #618- Top
Yes,
And here is the reply, typical of other such companies:
"Thank you for your inquiry. We sell complete harnesses. The connector you refer to is part of the dash harness, part 01200. This is in stock for $403.00."- Top
Fallback Position
George,
In the absence of finding a connector for the coming driving season I will probably remove it and individually wire each terminal (without cutting the original wires). The pic shows a little trial work on a spare ignition in the basement. Those wires are very secure. I never want to lose the complete electrical system again. It is unnerving not to mention downright dangerous.
- Top
Re: Fallback Position
Jack,
That is a very kind offer! But I don't believe the 1965 connector has the nylon locking tabs with hook ends that fit into the slots in the switch body as does the 1967. If I am right, that begs another question: How is the 1965 connector held in place?- Top
