Thanks to those who replied to part 1. I have now used both the UV dye and powder method to establish that the leak is in fact between the pan lip and the bottom of the timing cover not the crank seal.
Still looking for thoughts on sealer for the front of the pan. I know I should not need it but I am out of other ideas. Original oil pan and timing cover which I really want to keep. They seem to be undamaged. Current pan gasket is the correct for early style pan one piece (I tried with the original style gaskets twice) but I continue to have a small but constant drip (even without the engine running) between the lip of the pan and the timing cover. Any help would be appreciated.
