1961 tire issue - NCRS Discussion Boards
1961 tire issue
  • Russell #46855
    1961 tire issue
    I recently purchased a 1961 Corvette. It currently hasthe original wheels/hubcaps and 4-ply tires. I would like to up grade this to a set of Cragar ss wheels and while/redline tires. i would like any advice on the wheel/tire size. thanks in advance.
  • Jim K.
    • August 31, 2000
    • 554
    Re: 1961 tire issue
    I have 225-70-15 BF Goodrich on 5" wheels on my 61 and they fill the wheel wells nicely. I know the 5" wheels are narrow, but they have been fine for the last two years and 15K miles (most of it at 75-80mph) I had a set of 7" Cragar ss with the next size smaller, 215's I want to say, but they didn't fill the wheel wells enough. Either set up has no rubbing anywhere. I can e-mail you a couple of pic's (I don't do the posting thing well, way too complicated - the Vetteheads postings are much simpler).
    Good luck!
    Jim
    • Terry D.
      • May 31, 1987
      • 2690
      Re: 1961 tire issue
      Russell
      Most people run either 205's or 215's up front. Anything larger makes the steering a little hard to handle especially in tight spots. The larger tire does fill the wheel opening better but I guess it is a matter of personnal choice. I run 215 Radial TA's up front and 225 Radial Ta's in the back and like it very much. Both sets run on 7 inch GM rally wheels. You will be amazed at the difference with newer tires on your car.
      • Mike B.
        • November 1, 2004
        • 389
        Re: 1961 tire issue
        I believe my tires are 2.25-70 15 all around (I can check tonight and will correct it if I am wrong). Here is a photo of them mounted to my '61. While certainly not NCRS correct those old-school Cragar SS rims sure look period correct. Those are what I wanted when in high school - regardless of the car on which they were mounted.
        There is no rubbing and steering response is fairly quick and light.
        And sorry but I did everything I know to shrink to photo to screen size but could not get it to work.
        • Mike B.
          • November 1, 2004
          • 389
          Re: 1961 tire issue
          I guess the photo did shrink down after all!
          • Russell #46855
            Re: 1961 tire issue
            I appreciate all the feedback. Although a new member, I am truly impressed with the support and interest. I look forward to many years of participation with this wonderful group of Corvette lovers. For Mike, what size Cragars do you use? Russell #46855
            • Jim K.
              • August 31, 2000
              • 554
              Re: 1961 tire issue
              I have pics of both the Cragars w/ 215's and the steel wheels with 225's I can send via e-mail if you want.... I can't figure out this posting thing...
              Jim
              • Jim K.
                • August 31, 2000
                • 554
                Re: 1961 tire issue
                Here's the Cragars and 215's... I hope
                • Jim K.
                  • August 31, 2000
                  • 554
                  Re: 1961 tire issue
                  Got it!!!
                  • Jim K.
                    • August 31, 2000
                    • 554
                    Re: 1961 tire issue
                    OK I think I got it... I had a double HTTP thing going on...
                    Here's the steel wheels and 225's...
                    • Jim K.
                      • August 31, 2000
                      • 554
                      Re: 1961 tire issue
                      Last one close up of steel wheel 225
