The 2 cone shaped assembies are inserted through holes in the body and three screws hold each one in place. The AIM indicates that glue was applied to the base of the cone, presumably to seal against water leaking in. What is the preferred way of effecting a seal here. I was thinking of using some body caulking/sealer on the outside seam made by the assembly and the hole.
Steve
Steve
