My engine builder wants to put my block in an oven at about 550 degrees and then shot blast it. What does this process do to broach marks? Thanks in advance for your input. Jimmy
Shot Blasting C1 1959 283 Engine Block
Bolt a cover over the pad
I would not trust anything else to cover the pad. Should not be hard to make a shield of some kind that could be bolted to the block to cover the pad area. Dont trust anyone with your pad! Phil 8063- Top
Cover it...
Mine is at the machine shop as we speak. Get 1 1/2 x 1 1/2 angle iron. cut 4" length and drill hole to bolt to upper water pump hole. Might have to grind the radius a bit to get it to fit tight. I will be getting my block back in about 2 wks. I will let you know.- Top
