Trying to finish up and had a question, where the rear storage area carpet turns up against the fuel tank area bulkhead, how are the rear window storage tray hinges cut out of it? Some sort of flap like the front seat mounts? If so, to what dimensions and which way does the carpet "hinge"? Or is it just a vertical slot cut with a razor knife? Thanks!!!
C-3 70 Coupe Rear Carpet
Re: C-3 70 Coupe Rear Carpet
Thanks Chuck, the Aim shows a big dotted square and says to remove the carpet for the hinge (I don't remember seeing that not the first 50 times throught the AIM ). I think I'll cut the small slot for now, that leaves the option to cut out and remove a larger piece if needed. Just waiting for some misc seat hardware in the mail and I will do the second seat and then get it ll back together. Thanks again!!!
Jim
P.s. was I supposed to shoot a picture of my alternator bolt for you a while back??- Top
That is what the AIM says...the best advice would be from an interior judge if original varies from the AIM (and sometimes it does). Without any other input, I would follow the AIM.
I vaguely remember someone saying they would get me a picture of an alternator bolt. Even a good description of the head stamp would be helpful.- Top
