fused or not? - NCRS Discussion Boards
fused or not?
  • Rick Garrett
    fused or not?
    Are the power door locks fused or not? Mine dont work, yet I cant find any listing of a fuse for it.(wanted to start there before taking off the door panels) Nothing happens on either lock when either switch is depressed? I am also having a power drain on my battery, wanted to make sure everything worked before trying to track that down.
    thanks
    Re: fused or not?
    Rick-----
    The power door locks on late 70s C3 Corvettes are usually fused through the Courtesy Lights and Clock fuse. Usually, this fuse is labelled "CTSY-CLK" on the fuse panel. However, if your courtesy lights and clock are working, it is probably not the fuse that is causing your door lock problem.
