'65 Sidepipe Covers - NCRS Discussion Boards
'65 Sidepipe Covers
  • Joe Ciaravino
    '65 Sidepipe Covers
    My sidepipe covers were in pretty bad shape. There were some deep scratches, and the forward sections just behind the front wheels were sandblasted from the tire "kick-up".
    I had what was left of the original adodizing stripped off, then I polished the shiny parts to a beautiful finish after removing the scratches, etc. For the dull recessed areas, I plan on painting them with Eastwood Rally Wheel Silver paint as per the (erroneous) NCRS Judging Manual after prepping the surface.
    I would like to spray the entire covers with clearcoat to prevent oxidation, but am concerned about yellowing. All anodizing shops that I have contacted tell me that if I have them "bright dipped" and then re-anodized as in the original process, that all areas of the covers, including the dull sections, will take on a shiny finish. Apparently, these parts were originally produced using a complex and expensive process. Re-masking and "vapor blasting" the dull sections was mentioned, but is very expensive to re-do.
    Any ideas on the clearcoat?????
    Joe
  • Brandon K.
    • April 1, 1997
    • 474
    Re: '65 Sidepipe Covers
    Eastwood has some new clearcoats that arent supposed to yellow. Or, you may want to try just using a regular urethane clearcoat with some flattener added. This will probably give you the best protection. Only concern with any clearcoat will be adhesion, unless you rough the parts a little to give some bite. There are also some plastic shields available specifically for the side covers to protect from rock damage.
    BK
    • Bill D.
      • January 1, 1985
      • 76
      Sidepipe Cover Shields
      The shields Brandon mentioned are in Driveline from Nishna Valley. I have used them and they protect the front curve very well.
