WCFB carb - NCRS Discussion Boards
WCFB carb
  • Ron
    WCFB carb
    I guess I'm on a roll here. Hope I don't wear out my welcome! I bought a complete 60 passenger car motor several years ago and on it were a number of interesting pieces. Included were a 57 vette intake, bellhousing, and a WCFB carb. There is no tag on it. Is there some way I can identify it through the Carter numbers on it? Is there a specific reference I can use where these numbers are listed? There are numbers, but they don't seem to match anything in books I have. Thanks (again!) for your help.
  • Bill Clupper
    Re: WCFB carb
    What are the numbers on the Air horn and center bowl? Maybe someone could help if that info were provided
    • Ron
      Re: WCFB carb
      The only numbers I can find are 6-1271 on the upper portion and what looks like 0-108 or 0-1081 on the body of the carb.
      • motorman
        Re: WCFB carb
        if you e mail me the throttle bore diameters and the venturi diameters i may be able to tell you what engine it came off of but the same size carbs came on a lot of engines. if you are sure it came off a chevy engine we may be able to come close.
