'74 Coupe Door Alignment - NCRS Discussion Boards
  • Mel Goff #33968
    Does anybody have any suggestions as to aligning the doors to maintain an even gap at the strike side? I am not sure if factory assembly utilized shims to accomplish this. Both doors have a slight drop at the strike side, (about 1/8-3/16") just enough so that the peak of the body/door do not match perfectly as I would want. If factory shims need to be used at the hinge side, I would appreciate what material they are made from and possibly where I can get them. Both doors close and latch very well....just trying to get a better reveal.
    Thanks in advance......Mel
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: '74 Coupe Door Alignment
    Mel,
    Check to see if the hinge bolt holes into the door aren't slotted. I seem to recall that you can move the entire door rearward/forward, or you can move the top or bottom door edge more than the other. Probably originally intended as a "rough" adjustment to get it in the range of shims for the assembly line. Sorry I can't confirm, my hinges are packed deep in a storage box.
    You are probably going to need a helper; Proceed carefully to avoid boogering your paint or fiberglass.
    Chuck Sangerhausen
    • Mel Goff #33968
      Thanks for the input Chuck...it's much appreciated.
      Mel
