Are there any radiator fan schroud seals on a 67 L-71? Books are not clear about non-air cars.
67 BB RADIATOR FAN SHROUD SEALS, NON-AIR
One More Thing
Rano-----
I should have mentioned, if you have a problem with your big block OVERCOOLING, then you don't want to use the AC radiator seals. Some Corvette big blocks have a problem with too much cooling capacity and can't even get up to operating temperature even under hot ambient conditions. In this case, if you use the seals it will only make matters worse. However, if you happen to have the occassional big block that runs hot, the seals might help you.In Appreciation of John Hinckley- Top
