Diamondback Goldline Tires - NCRS Discussion Boards
  • Tim Genovese
    Does anyone have any experience with the 205 75 15 or 215 70 15 goldline tires being produced by Diamondback Classics?
  • Joe
    Re: Diamondback Goldline Tires
    My interest was piqued by your message, so I searched the web for info on Diamondback tires. I don't know if this is the same company, but what I found was a company in the U.K that has retreads in the sizes you mentioned. Their "tyres" retain the original sidewall, but have a new tread pattern. The company specializes in 4x4 retreads, but the tire that most closely matched your description was called the "Road Pattern" and the associated photo was a Eagle GA retread. There was no mantion of a goldline retread. In case you want to check it out, the web address is "http://www.btinternet.com/~bronco4x4tyres/bronco.htm".
    • Tim Genovese
      You can check them out at www.widewhitewalltires.com.
      They are located in South Carolina.
