C - 1 Window Regulator Lube - NCRS Discussion Boards
  • Jimmy J.
    • May 31, 1988
    • 304
    What kind of lube should be used on window regulator gears? Thanks, Jimmy
  • Brad K.
    • August 31, 1990
    • 414
    Re: C - 1 Window Regulator Lube
    Jimmy,
    I used a NAPA silicone based stuff called Sil-Glyde (part #765-1351) It comes in a 4 oz. squeeze tube. It says its "non-melting, non freezing, non-gumming and weatherproof". It's nearly clear and the consistancy of axle grease. It's working great on my regulators!
    Brad
