1965 rear axle specifications - NCRS Discussion Boards
  • Joseph E.
    • March 1, 2006
    • 175
    I'm in the process of completely rebuilding the rear axle of my '65 roadster and was wondering if the clearance values and bearing pre-load specifications for this unit are the same as those for 1966 and 1967 assemblies. I don't have the manuals yet for the 1965 model year but do have those available for both '66 and '67. Can the information in either of these references be used reliably for '65 driveline component rebuilding (wheel bearings, Muncie transmission etc.)? Also, do the members have any input, positive or negative, regarding collector car insurance through J.C. Taylor? Thank you for any responses posted.
    Joe
    #45420
    • 15610
    Re: 1965 rear axle specifications
    '66 and later COM/CSM axle and rear suspension info is applicable back to '63. The Muncie overhaul data should also apply to '65.
