I need a little help please - there seems to be nothing in the archives on this question.
I would like to find out what the correct part number is for the smog pump assembly for a 427/390 1969 (a late 68 build date if that matters)? I have researched Prince's Corvette Restoration Guide and also Bizzoco's Guidebook and also the '69 AIM. I am coming up with different information between sources. Please advise on:
smog pump part # (7801149?, 7803948?, other?)
diverter valve #
As best I can determine, the correct pump should not have a relief valve (apparently, they only appeared on the higher HP rated BB's)
I know what the correct pulley number (3925522) is so I don't need that. But, any other key numbers that might be helpful on this assembly are also appreciated.
Thank you in advance to any AIR gurus.
Dave B.
diverter valve #
Dave B.
