70 Wiper Motor Ground Terminal - NCRS Discussion Boards
  • Lawrence Berte
    I'm looking for the correct location (as in which of the 3 washer pump, to wiper motor screws) to fasten the "L" shaped ground terminal to.
  • Chuck S.
    • April 1, 1992
    • 4668
    See The AIM...
    UPC 12, Page A8...Appears to be the one on top directly behind the washer pump.
    • Lawrence Berte
      Re: See The AIM...
      Thanks Chuck. I checked the 1970 AIM yesterday and found the ground to show the 1969 mount position. I contacted a friend today to have him look at his '70, which was easy to see the wiper asm. since I have his 454 on a stand in my shop. Turns out it is mounted on the left (drivers) side lower screw, right next to the main wiper washer harness plug. I believe the '69s mount to the top screw due to a component mounted on the left side. Same holds true in the 68-72 VETTE-Vues Book illustrations.
      • Chuck S.
        • April 1, 1992
        • 4668
        Re: See The AIM...
        I've noted before that the AIM doesn't always match the actual cars, but with no other input, it would be my first choice. Apparently the error was a drawing revision that never got made. I'll make a note on that page for future reference. Thank you, Lawrence.
