I am putting together a 54 vette 235 engine. Correct block but I do not have the corvette water pump. I tried a stock 54 chevey water pump and it will bolt to the block but original fan and pully won't attach to complete the set up. The 54 Chevy pump has the pulley attached while the setup I have for the Corvette has a seperate pully and fan.
Is there a way to use the Chevy pump while I try to locate a correct Corvette water pump?
Any ideas on locating a correct pump?
