I'm trying to find out how to dissassemble C-1 power window switches. I want to remove the bezal from the drivers side switch for re plating but don't want to break anything in the process. Any help appreciated. Rich
C-1 Power Window Switches
Tags: None
- Top
Re: C-1 Power Window Switches
The switches are removed from the panel. I want to seperate the bezal from the switch.- Top
You see those little spring clips ,now look at the bezel (side) housing and see the little holes , the clips have a tang holding them in ,push the tang inward as you pull the clips up and out later re bend the tags out so they will again catch the housing bezel .- Top
