Were very early 3963512 cast 427's used in 69's - NCRS Discussion Boards
  • Jacob A.
    • December 1, 2003
    • 238
    Hi I have a 3963512 block for sale locally. A potential buyer has told me that an NCRS judge told her that very early production 3963512 blocks such as mine,(I believe the date is J-10-8,) weren't installed in Corvettes at all.
    According to the Black Book this casting # 3963512 was used in 69 Corvettes. If block casting date proceeds the build date of the car by 6 months or less... it is acceptable for judging.
    So what would the actual story be?
    thanks,
    Jacob
    # 40987
  • Dick W.
    • 10483
    Re: Were very early 3963512 cast 427's used in 69'
    512 blocks started showing up in the 2nd or 3rd week of December '68.
    Dick Whittington
    • Jacob A.
      • December 1, 2003
      • 238
      Thanks Dick,
      Do you mean that a 69 Corvette with a build date the 2nd or 3rd week of December '68 or later could very well have had this 3963512 block dated Oct 10 68?
      Jacob
      #40987
      • Dick W.
        • 10483
        2 bolt usage started in Oct '68 and 4 bolt started in late October '68
        Dick Whittington
        • Mark #28455
          The block castings overlap
          I personally own a 435 HP engine from approx car #6700 that is a 439 block cast F 8 and machined 10 31 68. The blocks were not selected in date code order for assembly. They were cast in order - 439 first, then 270 then 512. The first 439 blocks had cast clearances for the cranks that were too small for a 454 with 7/16" rods. Around May or June 68, I believe the blocks were machined for more clearance. The 270 blocks had this clearance cast in as did the 512 blocks. So, your block could have been used in a Corvette.
          Mark
