Engine Cleaning - NCRS Discussion Boards
Engine Cleaning
  • Rob H.
    • April 30, 2006
    • 121
    Engine Cleaning
    Could someone please recommend the best product or solvent in which to clean the engine and under undercarriage? I used one of the degreaser sprays, but they are very harmful for the hoses etc. Are the citrus sprays (P21S) any good?
    Any advice is greatly appreciated.
    Best,
    Rob
  • KEN EDMUNDS
    Re: Engine Cleaning
    Simple Green is very non invasive-it won't hurt a thing.
    • Eric J.
      • March 1, 1980
      • 771
      Re: Engine Cleaning
      I start with a little Dawn Dishwashing liquid and I use simple green, when I need something with a little more power. I keep a spray bottle with nothing but distilled water in it to rinse off what I just cleaned. lots of clean rags. Eric
      • Robert S.
        • July 31, 2004
        • 377
        Re: Engine Cleaning
        Here's a link to an article that may help you...
        Corvette Mag Engine Detailing
        Bob
        • Rob H.
          • April 30, 2006
          • 121
          Re: Engine Cleaning
          Your advice is much appreciated --
          Rob
          • Paul B.
            • January 31, 2007
            • 310
            Re: Engine Cleaning
            Be careful with straight Simple Green on bare aluminum if it's warm, it's corrosive and will etch the aluminum. Also be careful with your exterior paint, it will strip any wax.
            Paul
            • Wayne K.
              • December 1, 1999
              • 1030
              Re: Engine Cleaning
              Rob,
              Your local Honda motorcycle dealer should have a product called Hondabrite. I believe it is a P21S product or the likes of packaged in their container. I've used it for years and works great if you don't have any heavy buildup.
              Wayne
              Enjoy new and used powersports sales, expert motorcycle service and strong community roots at World of Powersports, proudly serving Central IL since 1993.
              • Rob A.
                • December 1, 1991
                • 2126
                Re: Engine Cleaning
                I've had good results with 409. Continue to rinse it off with more 409, instead of water until you're happy with the results. Not using water will eliminate causing any surface rust on any bare steel present. If you buy concentrate 409 you can choose how strong to mix it.
                • Anthony S.
                  • April 3, 2008
                  • 183
                  Re: Engine Cleaning
                  I've used Castrol Super Clean as a degreaser w/ great results
                  • Bryan L.
                    • June 30, 1998
                    • 397
                    Re: Engine Cleaning
                    I'm also a big fan of Super Clean, you can get it in gallon jugs at WM for around 8 bucks. Don't get it on the paint.
                    BL
