C-2 Fan and Clutch F - NCRS Discussion Boards
  • Edward M.
    • May 31, 1993
    • 17
    Does an original fan for an early 1966 have the part number on it or were there some without. I'm assuming all had the H and W codes. Also were Eaton clutch fans installed in Sept/Oct,unmarked or marked with a part# and date coded?
    Re: C-2 Fan and Clutch F
    The only fans with PN + date code embossed on them were some of the 7-blade units used on A/C cars. Fan clutches did NOT have the GM PN on them, but some were dated on the side of the drive hub.
