c2 paper air filter - NCRS Discussion Boards
c2 paper air filter
  • Keith G.
    • October 31, 2006
    • 316
    c2 paper air filter
    The wire screen has to be at a 45 and square, but does it need to be perfectly square or can it be a little bit diamond shaped?
    Re: c2 paper air filter
    Keith -
    The photo below shows what they're looking for - it's a Paragon reproduction of the A212CW, which is about as close as you're going to find unless you pony up really BIG bucks for an original.
    • Nick Culkowski
      It is not a major deduct by any means, and given the dollars per point argument, John's solution is likely the most practical. Here is an original.
      • Wayne M.
        • March 1, 1980
        • 6414
        Who's paying big $ for square (vert'l/horiz) mesh
        This one on eBay went for $ 472; another for $ 586. Was there another GM vehicle or year requiring these ?
        • Barbara S.
          • April 30, 1981
          • 599
          Ask Pete Lindahl
          Pete Lindahl showed me an original when I was getting my car judged at the Albequerque event last Fall. Maybe you could get Pete to post a photo of his original air filter.
          Tony
          • John Daly
            Nick,
            Is that filter an original or a service replacement with the correct mesh?
            At the judging retreat in dallas a few years ago I remember we were shown an assembly line AC filter on one of Chris Piscatello's cars that had small indentations around the diameter of the rubber portion. The AC part info was also debossed on the top surface.
            thanks
            jd
            • Nick Culkowski
              This one has the indentations and debossed AC part info you describe. I believe it is an original factory installed filter.
              • Nick Culkowski
                Top view showing indentations.
                • David D.
                  • 330
                  Re: Who's paying big $ for square (vert'l/horiz) m
                  Wayne, I may be wrong, but I seem to recall the same filter being used on some light duty GM pickups, not sure which years though. FWIW. Dave
