C3 Seat Shim Washer Dimensions - NCRS Discussion Boards
  • Robert S.
    • June 30, 2001
    • 230
    I would like to know the diameter and thickness of the round washers that are used to shim the seat backs on a C3 (mine is a 74'). I believe the car came with 8 of these washers. Hopefully someone has some original washers and can measure them and post a response.
  • Gary Schisler
    Re: C3 Seat Shim Washer Dimensions
    The only place that I have seen them in repro and original is Sal Carbone's Restoration Parts Outlet, http://www.restorationpartsoutlet.com/ You might try him and see if he will give you the dimensions.
    Gary
    • Jeffrey S.
      • May 31, 1988
      • 1879
      Robert:
      I have the original round (and rectangular) shims that came with my '69. I can get over to where the car is being stored for the winter in the next day or so and get 1 out and give you the measurements.
      Jeff
      • Sal C.
        • December 1, 1984
        • 430
        Jeff, Your '69 is going to have different shims and washers than Robert's '74.
        In any case, the 1970 through 1975 round washer is approx. 15/16 inch in diameter, 1/8 inch thick, and has an 11/32 inch hole.
        • Stephen B.
          • April 1, 1988
          • 876
          Zip Products sells shims & bag *NM*
