My "spring ring" style battery cable terminal seems too large for the post on my battery disconnect switch. Is there a way to install a battery disconnect switch using "spring ring" terminals? Thanks, Craig
C2 Battery Disconnect
Tags: None
- Top
Re: C2 Battery Disconnect
Are you trying to put the disconnect on the positive or negative side? The negative battery cable is sized for a smaller battery post than is the positive cable.Bill Clupper #618- Top
Agree with Bill
Mine is installed on the negative terminal and has dine fine for a number of years.
Kent #6201Kent
NCM Founder - Member #718- Top
Upon further review, it fits OK. I originally thought the disconnect post was smaller than the small neg. battery post, but they are the same so the "spring ring" fit is fine after all. I apologize for the error. Thank you Bill for your response. Craig- Top
