J-56 Brake Brackets Numbers - NCRS Discussion Boards
  • Roger A.
    • April 30, 1982
    • 49
    On the J-56 Heavy Duty Brake support brackets, are the part numbers cast into the brackets or raised on the brackets? The brackets I have are numbers 3948879 and 3948880 with a double diamond and an 8 by the number. Is the 8 a date code? What does the double diamond denote? Thanks! Roger Allgood
  • Anthony S.
    • April 3, 2008
    • 183
    Re: J-56 Brake Brackets Numbers
    Roger,
    I Don't know about the diamonds, but here's a look @ a pair.
    Anthony
    • Howard Nardick
      #879/#880 are the later brackets the ones with raised numbers are the early ones, the double diamond is probably a foundry mark.......HN
      • Dick W.
        • 10483
        While these are probably original? beware that there are repro brackets also.
        Dick Whittington
        • Mark #28455
          69 and newer *NM*
