C1 Ign. Switch - Keeping Key In - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi all,
    I would like to PV my car, but my ignition switch is such that the key can be removed in any position. I talked with one repairer who may be too busy to get to it in time. Is this something that can be done in my garage? How should I proceed?
    Bob
  • Paul M.
    • November 1, 1987
    • 142
    Re: C1 Ign. Switch - Keeping Key In
    I would have a new key cut 1st. Sometime that will do the trick. Otherwise you will need a lock smith to change the tumblers inside.
    • Robert S.
      • July 31, 2004
      • 377
      So what's the problem, 53-62 ignition keys can be removed from the lock cylinder in any position.
      Bob
      • Bob B.
        • March 1, 2003
        • 831
        Bob,
        Both the 58-60 Judging Guide and the 53-62 PV manual state that the key cannot be reomved, with normal effort, in the off position. If these guidelines have changed, please let me know, as that will save me the trouble of fixing it.
        Bob
        • Dave S.
          • August 31, 1992
          • 2918
          Bob,
          I don't believe that requirement has changed. Its one of the things I had to address in preparing my 61 for PV this year. Do you have an original Delco switch and cylinder.???
          • Bob B.
            • March 1, 2003
            • 831
            Dave,
            Yes, both switch and cylinder are original.
            Bob
            • Jimmy J.
              • May 31, 1988
              • 304
              Bob, I had my switch repaired at a local lock smith for $5.00 and he recovered the key number for me from the inside. I did it for the same reason, the PV. Good luck, Jimmy
              • Dave S.
                • August 31, 1992
                • 2918
                Bob,
                If both are originals then Paul's comment above is in order. Something is worn and its most likely the cylinder and/or the key. Does your chrome bezel on the cylinder have just 1 small hole.??? I know for 61 the originals had 1 hole. Not sure about 58-60.
                • Bob B.
                  • March 1, 2003
                  • 831
                  Dave,
                  It has one hole and this is correct for 58-60. Looks like its time to work!
                  Bob
                  • Dave Suesz
                    Well, '55 #518
                    has the original lock cylinder, and a set of NOS GM keys which were professionally die-cut, not ground, to the original lock numbers, and the key is a nice snug fit in the lock. The key can be removed in any position, and I can tell you that this has been the case at least since 1964, when I first was old enough to notice such things.
