Recently had my engine rebuilt at a shop. When I droped off the car everything worked, I mean everything. When I pick up the car the mechanic tells me my new battery is bad, it keeps going dead. As I drive home the amp guage is way above where it should be. At home I disconnect the battery and fully charge it to 13 plus volts. Let it set a couple of days off the charger and check the voltage again. 13 plus volts. then I hook up the battery and find that there is a steady 3.5 volt drain. While trying to find the source of the drain I discover that my heater no longer works and there is voltage going into the motor even though the switch is turned off. Then I find that all my wipers do is make one clicking noise when I operate the switch. I did not find the source of the drain.
What could they have screwed up, there is only a handfull of wires to disconnect. They all seem to be hooked up OK right now. Any ideas?????
Thanks, Bill
Thanks, Bill
