65 non power master cylinder leak - NCRS Discussion Boards
  • Chris H.
    • April 1, 2000
    • 837
    #1
    The fluid actually seems to be oozing through the casting of the master cylinder. Is this possible? Has anyone ever heard of this?
    The fitting for the line is bone dry and so is the area where it mounts to the fire wall.
  • john daly
    Re: 65 non power master cylinder leak
    Leaking through the casting itself is known as porosity. I've seen it on new castings, but not on older ones.....are you sure there's not a crack in it? J.D NCRS # 19684
    • Chris H.
      • April 1, 2000
      • 837
      If it is a crack I can't see it. I think it's a repro cylinder as the lid is unpainted.
