C1 or C2 Power Window Motors - NCRS Discussion Boards
  • David Dawdy
    I have two motors, one is stamped 5045156 on the housing with a large C and smaller 3 - 59, and the other is 5045171 with a D2 - 60. The numbers are not located in similar locations. The 5045171 unit has a grounding pin riveted on the housing, the other does not. What do I have? Should 1960 motors be round or could one of these be a 1960 application if the 3 - 59 is a date stamp?
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 or C2 Power Window Motors
    OK I think all C1's were round but may be 61-62 are not!
    • David Dawdy
      Roy, that was my thought,however Mike Ernst in his '(Early) Power Windows' article indicates 61 - 62 were of the square type. I definitely have two of a kind due to the difference in grounding pin and stamp location. Some restorer's have said use the 'square' motot because it is stronger and no one can see it anyhow. It is a quandry we put ourselves in, how far to go . . .
      • Roy B.
        • February 1, 1975
        • 7044
        David! Well ether one will work and you don't see it, looks like I was correct ! The Chevy use the round type also . May be because the 61-62 doors were different. Like so many things if it's not in the JM many don't care or know.
        • David Dawdy
          Thanks Roy, I'm a bit of a purist and would prefer the correct set up but it is difficult to do 47 years later. This old wreck may never see a judging field.
          • David Dawdy
            • Roy B.
              • February 1, 1975
              • 7044
              Re: C1 or C2 Power Window Motors "David"
              I'm a purist also on everything and like you never thought I would enter judging but did in 05 ,because of my accessories I thought it would never make third flight, but WOW it got top flight.
