Lifter problem? - NCRS Discussion Boards
Lifter problem?
  • R N.
    • May 31, 2002
    • 640
    Lifter problem?
    Hello All,
    I removed my intake manifold on my '70 Z28 to install the correct # 110 manifold and noticed one of my lifters looked different from the others. This lifter is the first one at the front # 2 cylinder. (See attached photo)
    Does that ring (disk} just snap back into place, or do I need a new lifter?
    And one other question from a gearhead newbee, how do I tell if these are mechanical or hydraulic lifters?
    PS: Sorry this isn't a Corvette question.
    Best regards,
    Kurt N.
  • Stephen B.
    • December 1, 1984
    • 98
    Re: Lifter problem?
    I would probably replace the lifter the retaining clip is amoung the missing they are most likley hydraulic lifters . even if you could get a clip or found the old one i do not think you could trust the lifter after being run like that steve
    • Wayne K.
      • December 1, 1999
      • 1030
      Re: Lifter problem?
      Kurt,
      If it is an original 70 Z28 motor it would have solid lifters.
      Wayne
      • Clem Z.
        • January 1, 2006
        • 9427
        Re: Lifter problem?
        that is the pushrod cup retainer. just press it flat and press it into the lifter
        • R N.
          • May 31, 2002
          • 640
          Re: Lifter problem?
          Wayne & Clem,
          Motor was a new GM short block purchased back in the 80's when you still could buy one. I was told by the guy who installed the engine that the lifters were solid.
          Clem, is there a clip or something to hold it in place, or does it just snap back into place.
          Thanks for the help.
          Kurt N.
          • Clem Z.
            • January 1, 2006
            • 9427
            it is a press fit into lifter,no snap ring
            press it flat and then press it back into the lifter using a rod that will be a close fit to the inside diameter of the lifter bore. it should lock into the lifter.
