I'm replacing my lower radiator hose, and want to remove all the coolant from the car. The radiator is drained, but I'm not sure where to drain the coolant from the water jackets in the block. There are two bolts, one on either side, about one inch above the oil pan flange, both angled downwards - are these the ones I want? This is a mid 70's era 350.
thanks
thanks
