(Message Deleted by Poster) - NCRS Discussion Boards
  • nick evanochko
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: courtesy lights
    The courtesy lights work by completing the ground when the doors are open etc. They always are have 12v available on the orange wire. The light switch also completes the ground when in that courtesy light position. I believe the switch depends on the cluster ground (#12 brown) connection for ground.
    Do the instrument lights etc work? If not, check to insure that the ground is connected. You can also run a jumper from the metal of the body cage to the instrument cluster and see if the lights work. If not, then you have a problem with the switch or associated wiring (#20 white wire on switch)
    Good Luck
    • nick evanochko
      Re: courtesy lights
      steve everything works except i cant turn on the interior lights by rotating the headlight switch thanks nick
      • Stephen L.
        • May 31, 1984
        • 3148
        Re: courtesy lights
        Remove the white #20 wire on the headlight switch. Using a jumper, connect that wire to a good ground (body cage metal) If courtesy lights work then switch is faulty. If not then that wire is open somewhere in the loom.
        • nick evanochko
          Re: courtesy lights
          steve problem solved connector was pushed on right next to courtesy terminal but on the bat terminal must of been like that for years and just noticed it. thanks again for your input. nick
            • 11608
            Re: courtesy lights
            Nick,
            Please don't delete your original post just because you got your answer. It leaves all the rest of the following posts "hanging" and really does not help anything.
            Patrick
