C2 jpstevens tag - NCRS Discussion Boards
C2 jpstevens tag
  • Jim R.
    • June 30, 2001
    • 643
    C2 jpstevens tag
    hi fellas i have a 65 with blue int, or the only blue int of 65, they call bright blue, and all of my original carpet tags have the color med/dk blue on them ,now if you order a replacement they put bright blue on the tag and dont acknowledge the med/dk blue ,any comments from other informed members would be appreciated. jim
    JR
  • Robert S.
    • July 31, 2004
    • 377
    Re: C2 jpstevens tag
    I don't know much about C2s but I'd say remove the bright blue tags and put your old med/dk blue tags on the new carpet
    Bob
    • Kevin M.
      • November 1, 2000
      • 1271
      C2 jpstevens tag
      Search for post by Art Armstrong on 65 blue carpet. He has worked with Al Knoch on getting the 65 blue correct. He's traveling so won't see this post.
      Kevin
      • Kent K.
        • December 1, 1982
        • 1139
        Jim, I had a similar delimma with my '67 which has white/blue interior. ACC had, at the time the only correct shade of blue carpet as the original (I removed the original carpet from my car during restoration). Posters seem to recommend steering clear of ACC due to fit and other problems. Al Knock is probably the only reproduction interior soft goods supplier worth his salt today. Others may have differing opinions I'd like to hear also. If AK would simply reproduce the medium blue carpet instead of relying on the bright blue, it would make a lot of NCRS people happier.
        Kent #6201
        Kent
        NCM Founder - Member #718
        • Randy R.
          • March 1, 1983
          • 477
          I have a 67 with a bright blue interior. I ordered carpet from Al Knoch. The color of the replacement carpet is much lighter than the original. I spoke to them and returned it to them for their inspection. I was told that was the best they can do.
          • Lawrence S.
            • April 1, 1993
            • 775
            I too have a 67 with bright blue/white interior. And when I got my carpet from Ak the carpet was in my view to light. I did not send it back b/c of previoius stories from guys that said the bight blue carpet just comes in different shades. I did send my dash pads back twice and finally decided just to re-dye my originals---best decision that I made.
