Is it possible to replace the rear license light fixture bulb socket and wire harness ? It apears to be riveted into the housing, similar to the front, yellow turn signal lights. Any way to get the bulb socket out ? or is it nescessary to replace the entire unit. On mine the wires are brittle and should be replaced. The housing is in good condition.
Rainer
Rainer
