C-3 Door Panels - NCRS Discussion Boards
C-3 Door Panels
  • Robert M.
    • June 30, 1992
    • 120
    C-3 Door Panels
    Hello everyone.
    My 1970 is in need of some new door panels. This car will never be a flight prospect, just to let you know. I would like to get the repo door panels. My question to you who know, who makes the best looking, best fitting repo door panels for a 1970?
    Thank you,
    Bob
  • Dick W.
    • 10483
    Re: C-3 Door Panels
    I think that you will find the general concensus here would be Al Knoch panels. They look and fit good..
    Dick Whittington
    • Robert M.
      • June 30, 1992
      • 120
      Re: C-3 Door Panels
      Thank you Mr. Whittington
      • Harmon C.
        • August 31, 1994
        • 3228
        Re: C-3 Door Panels
        Bob
        All the panels fit sometimes and require moving the lock most of the time.
        I think the doors must be different on one car to the next or the new panels are not all the same. With AK panels it can take from one to eight hours to get them to fit and so the lock can be turned with the key. Other brands are not much different for fit as none I have used fit easy on both doors.
        Lyle
        Lyle
        • Kent K.
          • December 1, 1982
          • 1139
          Re: C-3 Door Panels
          What color interior and is it vinyl or leather?
          Kent #6201
          Kent
          NCM Founder - Member #718
            Add On
            I've got Al Knoch panels on my '71 and wished I hadn't bought them... They're ROCK HARD compared to soft/supple originals and your elbow starts to hurt on long trips...
            The repro panels made by Corvette America compare better to factory originals in terms of softness. Plus, if it's for a driver application, you can save substantially by shopping their NQP (not quite perfect) inventory where you're getting a factory second that might have a cosmetic blemish 'somewhere'. These panels aren't 'junk' and the ones I've seen you have to look VERY closely at to find the cosmetic defect.
            Next comment. You can buy basic or deluxe panels. The come on with 'basic' panels is they have no trim pieces on them and you're told to simply remove the original trim components on your originals and install on the new panels. HAH! There are no pre-drilled holes to mount the trim components and you can expect to break a few of the crimp-over hold down tabs in the process... Save yourself a headache and buy the deluxe panels!
            Last comment. NOBODY makes reproduction panels that are 100% correct. They'll all have vacuum formed plastic backing vs. original formed cardboard. Some will have rivets vs. original staples holding the upper rubber. And, I've yet to see ANYONE duplicate the factory original accent stitching properly (color of thread + stitch pattern).
            • Robert M.
              • June 30, 1992
              • 120
              Re: C-3 Door Panels
              Kent,
              I have the Delux Black leather interior.
              • Dick W.
                • 10483
                Re: Add On
                Jack, you must have seen some CA panels that we have not seen. Don't fit, grain is incorrect, colors are off.
                Dick Whittington
                • Chuck S.
                  • April 1, 1992
                  • 4668
                  Many moons ago...
                  I bought the best matching door panels from Eckler's (GOLD Certified!)...heavy material, accurate color and grain, and nice accent stiching. They are built on ABS backing material, but I consider that an advantage rather than a disadvantage. But, "evolution" of repro Corvette interiors flows like a river, and lots of water has gone under the bridge since then.
